Northern Arizona Wind & Sun - Electricity from the sun since 1979Free Solar Electric Discussion Forum
Dancing Solar Electric Hippos
Valid CSS!
Solar Electric Panel Mounts
Home • Up • Solar Electric Panel Mounts • Solar Panel Installation
Unirac RV Mount Chart
Mounts for Solar Electric Panels
There literally thousands of mounts, configurations, and mount options for all the hundreds of various types, brands, models, and quantity of solar panels. They range from the simple bracket type mount for putting a panel on an RV, to rail type roof mount systems, and tracking mounts that follow the sun.
Mounts that we have for sale at our online store include Direct Power, Two Seas, Unirac, Kyocera, Zomeworks.
Types of Mounts
Panel mounts fall into these general categories:
  • Flush Mount
  • Roof-Ground
  • Top & Side of Pole
  • Rail Mounting Systems
Flush Mounts:
  1. Typical flush solar panel mount on an RV (Unirac)Flush mounts are the simplest type of solar panel mount, and are commonly used for single or small quantities of panels. They are often used on RV's. They generally consist of nothing more than end brackets or "Z" brackets that mount to the panel frame and then screw or bolt into the roof. Despite some disadvantages, these are still the type we recommend for most RV's and single or two panel roof mounts.
Advantages: Very cheap, simple to install, low wind resistance and weight. Very common on RV's.
Disadvantages: Not suitable for large arrays, some types of roofs. No flexibility in tilt or orientation. Panels usually must be pre-wired before installing. May be difficult to remove if RTV or other sealant was used on roof.
Roof-Ground Mounts:
A large ground mounted solar electric panel arrayRoof-ground panel mounts have been the mainstay for many years, especially for off grid systems. They are less popular with grid tie systems in cities, for appearance reasons, and because the large arrays often used in utility intertie solar electric systems can have a pretty high wind resistance. In extreme cases high winds may cause roof damage. Or worse.
Roof-Ground mounts are called that because they pretty much mount either on a roof or on the ground with little or no change in mount setup. All provide some kind of tilt, either adjustable or fixed. In very high wind areas they require a good anchor point or they tend to blow away, and that is not usually a good thing.
Roof-ground mounts are simple to install, but in some cases it is preferable to mount the panels first if you are mounting them directly on the ground, as the lower row of panels in multi-tier rack can be hard to get to. Many people raise them up a few feet by setting them on short poles, concrete blocks, or steel feet. This also keeps them up high enough so you don't get any panel shading from weeds or grass growing nearby.
Advantages: Relatively inexpensive, fits a wide variety of panels. Can be used almost anywhere - even on the side of buildings. Most are available with adjustable tilt for the best sun angle to produce the best power. However, tests done by Sandia Labs show that you only get about a 5% increase over a year by adjusting the tilt every 3 months.
Disadvantages: May require heavy earth or roof anchors in some areas with very high winds. May be less than esthetically pleasing (that means ugly) in your back yard. Some city codes may have limits or restrictions on roof structures and/or visibility.
Small Two-Seas Top of Pole Solar Panel MountTwo Seas Side-of-Pole mount with a small solar panelPole Mounts:
This includes Top-of-Pole, Side-of-Pole, and Tracking Mounts for solar panels.
Pole mounts, especially top-of-pole, have been popular for a long time. Top-of-pole mounts are essentially a steel or aluminum rack and rail system bolted or welded to a large sleeve that sets on top of a pole with set-bolts to keep in place. Side-of-pole mounts are often used when you need to mount to the side of a telephone pole or communications tower. Tracking mounts are similar to top-of-pole mounts, but they also have a method of automatically aiming the mount to follow the sun.
Zomeworks and Wattsun are the two major manufacturers of tracking mounts. Both have a wide variety of sizes available. Wattsun sells a 2-axis (tracks both vertical and horizontal), but in our opinion they are not cost effective - stick with the single axis type.
Top of pole mounts (including trackers) are one of the simplest (but not always easiest) of mounts to install. They essentially only need a single steel pole set in the ground (usually in concrete), and the mount slips onto the top of the pole. Most common sizes use a 2-inch to 8-inch pole, usually around 11 to 13 foot in length (11.5 foot is 1/2 of a standard 21 foot pipe). They can go higher - most commonly where you need to get the panel up more to avoid shading from nearby shrubs, or to keep animals such as cows and elk from using them for a scratching post if not fenced off.
Several companies manufacture top and side of pole mounts, including Direct Power, Two Seas, Zomeworks, and UniRac. Most have a wide variety of types to fit nearly any current solar panel. Our available mounts are listed on our online store.
There may be two hard parts to actually installing them - larger mounts will require a good anchor, which can mean in soft soil that you may have to dig a hole as much as 7 foot deep to avoid them being turned by the wind. The second is that large mounts can be very heavy, so you will need either a small crane, gin pole, or a few people to lift it up. One advantage of top of pole mounts is that they are very easy to wire up, since the back of the panels is easily accessible. We usually recommend that you do not mount the panels before getting the mount on top of the pole, especially for larger sizes. If something drops, you could have a smashed panel disaster.
Rail Type Mounts
under construction
General Mounting Information
Roof Mounting Clearance: Panels mounted on a roof should have at least an inch, and preferably 2 to 6 inches, clearance between the bottom of the panel frame and the roof. This allows for air flow under the panels for cooling. Panels should never be mounted so there is no air flow under them, as they can reach very high temperatures that way, just like car parked in the sun.
We carry all solar panel mounts from Unirac, Two Seas, Zomeworks, Wattsun, Direct Power, & Kyocera. We can special order mounts from most other manufacturers.
Northern Arizona Wind & Sun, Inc
Toll free Telephone: (USA only) 800 383-0195 (Flagstaff)
Technical Support: 623 877-2317 (Phoenix) or 928 526-8017 (Flagstaff)  FAX: 928 527-0729
Mailing and shipping address: 4091 East Huntington Drive, Flagstaff AZ  86004
Webstore for PRICING and online ordering, 24 hours/7 days a week
Email for information on Order Status:
For technical support, website comments, or questions email us at:
© 1997-2005 Northern Arizona Wind & Sun, Inc. and the respective manufacturers and may not be used without permission.
Last updated Tuesday, April 19, 2005
