Northern Arizona Wind & Sun - Electricity from the sun since 1979Free Solar Electric Discussion Forum
Dancing Solar Electric Hippos
Valid CSS!
Manufacturers Links
This page is no longer active and is being moved to http://www.windsun.com/General/links.htm
Links for various manufacturers of solar electric equipment and related products. Listed alphabetically. (under construction)
  • Anderson Power - High current connectors such as SB350 for batteries, inverters, etc.
  • Blue Sky Energy - MPPT charge controllers for solar electric systems 12 to 48 volts
  • Bogart Engineering - Battery system monitors
  • BP Solar - Major manufacturer of PV panels
  • Concorde Battery - Wide range of AGM sealed deep cycle batteries, including the solar PVX series.
  • Crown Battery - Deep cycle and heavy duty industrial batteries up to 6000 amp-hours.
  • Delta - Lightning and surge arrestors and surge capacitors for PV, residential, and industrial.
  • Direct Power - Solar panel mounts for all manufacturers. Roof, ground, top of pole, RV etc.
  • Flexcon Industries - Pressure tanks for well pumping systems.
  • Exeltech - Sine wave inverters from 125 to 1100 watts, and rack mount inverters.
