Northern Arizona Wind & Sun - Electricity from the sun since 1979Free Solar Electric Discussion Forum
Dancing Solar Electric Hippos
Valid CSS!
Air X Wind Generator
Home • Up
Air-X Wind Generator
AIR-X Wind Module
Air-X 400 Watt Wind GeneratorAir X Wind Generator From Southwest WindpowerThe AIR-X builds upon what has made AIR the world's #1 selling small wind turbine with new technology.
All of these features are primarily found within the body of the turbine. The microprocessor based turbine controller results in increased performance, improved battery charging capability, greater reliability and the reduction of “flutter” noise from the machine.
The controller allows for peak-power tracking of the wind by optimizing the alternator's output on all points of the cubic curve and then efficiently delivers the energy to the battery. The turbine’s smart controller allows it to actually control blade rotation speed thus eliminating the buzzing noise commonly found with the AIR 403 in high winds. Furthermore, new carbon-reinforced blades with a modified pitch angle further increases power production.
Much Lower Noise: Previous AIR wind modules relied on their aero-elastic blade design for protection in high winds. This caused a loud flutter noise in winds above 35 mph (16 m/s). AIR-X’s circuit monitors the wind speed and electronically slows the blades as it reaches its rated output preventing it from going into flutter. This results in a much quieter wind turbine. In high winds, the AIR-X will continue to produce power at a reduced level until the wind decreases, at which point maximum potential output will resume. The Benefit: Quieter and neighbor friendly wind turbine.
Improved battery charging: Previous AIR designs required 300-400 amp hour battery banks so the trickle charge of the wind turbine could be adequately absorbed. The AIR-X’s charge controller periodically stops charging, reads the battery voltage, compares it to the voltage setting and if the battery is charged, it completely shuts off all current going to the battery. This function is performed within a few milliseconds. The closer the battery is to reaching its full state of charge, the more often the AIR-X’s circuit repeats this action. This means any size battery bank from 25 to 25,000 amp hours or higher can be charged safely. When the battery has reached its charged state, the AIR-X will slow to an almost complete stop. Only when the battery has dropped below its voltage set point will it startup and resume charging. The Benefit: Extended battery life, no overcharging.
Lower stress design: AIR-X limits power on the input side of the electronics by controlling the torque from the blades. The power no longer has to be dissipated by the electronics resulting in lower stress on the circuit, bearings and other materials. Furthermore, stress on wind turbines occurs primarily in high winds. Under these conditions, the electronic stall design reduces the blade speed to 600 rpm, thereby significantly reducing turbine and tower loading while still producing power.
What's New in the AIR-X?
  • New microprocessor-based controller
  • Lower torque bearings allow for improved startup.
  • New series of carbon reinforced blades.
  • More robust tower clamp and yaw assembly for stronger and more secure tower mounting.
  • MPPT (Power Point Tracking)
Features
  • Unprecedented 3 YEAR WARRANTY
  • Carbon Fiber Composite Blades
  • Aircraft quality aluminum alloy castings
  • Exclusive Brush-less neodymium cubic curve alternator
  • Sophisticated internal battery charge regulator
  • Maintenance-free - Only two moving parts
  • Exclusive Auto-brake-feature that slows the AIR to a silent spin when the batteries are charged thus extending bearing life and reducing noise.
  • High Wind Safe Mode - Automatically slows turbine in potentially damaging winds and reduces noise.
  • Quiet Operation.
Applications
  • Remote homes & cabins
  • Water pumping
  • Recreational vehicles
  • Battery charging
  • Science & education projects
Specifications
  • Air-X wind generator estimated annual power productionRotor Diameter: 46" (1.14 meters)Air-X wind generator performance curve
  • Weight: 13 lbs (6 kg)
  • Start up wind speed: 7 mph (3 m/s)
  • Voltage: 12 & 24 VDC
  • Output: 400 watts at 28 mph (12.5 m/s)
Downloads - Instruction Manuals (PDF)
Air-X wind generator at a snowy cabinAir-X installation manual (this is for the current Air-X wind generators)
Air 403 Installation manual (this is for the older 403 wind generators)
Air-X & Air Marine - complete specifications brochure
Roof Kit Manual for AIR X & AIR 403 wind module roof mount Kit
27 foot Tower Kit Manual (designed for AIR X & AIR 403 Wind Module)
45 foot Tower Kit Manual (designed for AIR X & AIR 403 Wind Module)
Northern Arizona Wind & Sun, Inc
Toll free Telephone: (USA only) 800 383-0195 (Flagstaff)
Technical Support: 623 877-2317 (Phoenix) or 928 526-8017 (Flagstaff)  FAX: 928 527-0729
Mailing and shipping address: 4091 East Huntington Drive, Flagstaff AZ  86004
Webstore for PRICING and online ordering, 24 hours/7 days a week
Email for information on Order Status:
For technical support, website comments, or questions email us at:
© 1997-2005 Northern Arizona Wind & Sun, Inc. and the respective manufacturers and may not be used without permission.
Last updated Tuesday, April 19, 2005
