View Schneider Electric Conext Off-Grid Inverters, Grid-Tie Inverters or Accessories.
A Conext XW solar system provides up to 36 kW by using modular components. All components communicate with each other with out‐of‐the‐box network capability. They include the Conext XW Inverter/Chargers, the Solar Charge Controllers, the Conext XW Automatic Generator Start (AGS), and the Conext XW System Control Panel (SCP).
The Conext XW System is the ideal solution for homes connected to the utility grid, where owners want to incorporate a renewable energy system with backup power. The grid‐interactive functionality allows excess energy that is generated to be exported to the grid and allows the grid to act as an additional energy source to charge the system’s batteries. Grid‐connected homes can also benefit as the inverter will automatically detect a grid failure and instantly switch to backup power stored in the battery bank. When the grid is p y g active, the Conext XW System will monitor and regulate battery charging to ensure the batteries are ready to supply backup power when the grid fails.
The Conext XW System can process multiple forms of incoming power making it a popular choice for off‐grid applications (those not connected to the grid), as it provides homes with a completely autonomous supply of electricity. The Conext XW System can parallel up to four Conext XW Inverter/Chargers for single‐ or three‐phase systems. With a robust 6 kW power rating and 12 kW of real power output to start loads, homeowners feel comfortable knowing there is power to spare.
Backup Power:
Grid-connected homes can also benefit from the use of a Conext XW System as the inverter will automatically detect a grid failure and instantly switch to backup power stored in the battery bank. When the grid is active, the XW System will monitor and regulate battery charging to ensure the batteries are ready to supply backup power when the grid fails. XW Backup power systems may be used with or without solar, wind, or standby generators.
For information about updating your XW system firmware, click here.
