Comparing options for grid or solar home charging
Grid-based vs. Solar Home EV Charging Options: Costs and Benefits Comparison
Date Published:
If you’re thinking about switching to an electric vehicle, it’s important to understand that home charging may not be as simple as plugging your car into a wall outlet. While you certainly can opt to charge your EV’s battery through a standard 120v outlet, it can take a long time to charge and probably won’t be practical for your daily driving needs.
That means you have some choices in how to invest in charging for your EV. And while there are a range of upfront costs, with ongoing fluctuations in fuel costs due to a continually unpredictable fuel market, investing in an EV and home charging solution has some powerful benefits.
Understanding EV Charging Levels
There are three levels of charging, each with different speed, cost, and infrastructure considerations, and understanding them is key to choosing the right home setup.
Level 1 (120V)
Level 1 charging uses a standard household outlet with no special equipment needed beyond the charging cable that typically comes with your vehicle. You’ll trade convenience for speed, though, as most EVs charge at only 3–5 miles of range per hour at Level 1. A full charge can take 24–50 hours depending on your battery size. For drivers with short daily commutes or a plug-in hybrid with a smaller battery, this may be sufficient. For most full EV owners, it won't be.
Level 2 (240V)
Level 2 is the standard for residential home charging. It runs on the same voltage as large appliances like dryers and delivers 20–30 miles of range per hour, enough to fully charge most EVs overnight. It requires a dedicated 240V circuit and a compatible home charger. This is the setup most EV owners invest in.
Fast Charging
While there is technology for fast charging (20-45 minutes), this requires high-voltage commercial-grade equipment and is generally not practical or cost effective for home installation.
The real decision comes down to whether Level 1 meets your needs, or whether it's time to invest in a Level 2 setup. And once you've made that call, the next question is how you want to power it.
Grid-based Home EV Charging
The simplest path to home charging is to tap into your existing electricity infrastructure. If you are grid-dependent, your process can range from straight-forward to complex depending on your system’s age and how much upgrading needs to be done to support a charging system.
If everything is up to date, you can hardwire an EV charger into your existing panel and call it a day. However, if you have an older home that hasn’t been upgraded in a while, you may have other steps like upgrading your system panel, replacing old wiring, or adding GFCI protection.
In any case, your best bet is to hire an electrician for a full evaluation and, if needed, get a second opinion as well.
Pros and Cons of Grid-based EV Charging
✅ Low upfront cost (charger + installation)
✅ Simple installation
✅ Easy to upgrade
✅ Benefits are immediate—no waiting on payback period
❌ Increased electricity consumption
❌ Still subject to grid and utility dependency
For homeowners who want to reduce or eliminate their dependence on the grid, solar charging is the most powerful long-term option. The right setup depends on whether you're starting from scratch or building on an existing solar system.
If your home is already running on solar, adding EV charging is often a straightforward expansion. You just need to make sure your existing system has enough capacity to support the additional load of a level 2 charger, or make sure you can scale your system with additional panels and inverters. A solar installer can evaluate your current system and tell you what, if anything, needs to be added.
If you’re building a solar charging setup from the ground up, you're making a bigger upfront investment with a longer term payoff. A residential solar installation typically involves solar panels, an inverter, mounting hardware, and potentially a battery storage system. Costs vary widely based on system size, roof type, and location, but a full residential system generally runs $15,000–$30,000, although there are often state and local incentives and rebates that can help offset the cost.
It's also important to know which type of solar configuration you plan to set up.
  • Grid-Tied Solar: Connects your solar panels directly to the utility grid, using solar power during the day and grid-power during cloudy conditions or at night.
  • Hybrid Solar (Solar + Battery Storage): Grid-tied solar with an energy storage component to help further reduce dependence on the grid.
  • Off-Grid Solar: A system that operates entirely independent of the grid and provides the most energy independence.
You can find a more thorough explanation of each type in our article Solar 101: Grid-ties vs. Off-grid Systems.
Pros and Cons of Solar EV Charging
✅ Complete or significant reduction in energy costs
✅ Energy independence and resilience against grid outages (especially with battery storage)
✅ Net metering credits (in qualifying areas) for excess energy fed back to the grid
✅Reduces your carbon footprint
✅Improves home value
❌ Higher upfront cost than grid-only charging
❌ Payback period varies widely — typically 6–12 years depending on location, energy rates, and system size
❌ Complex installation requiring a qualified solar professional
❌ Solar production varies by season, roof orientation, and local climate
Home Charging: Do What Works for You
Bottom-line, how you approach energy independence is unique to your budget and needs, but it’s good to know your options for home charging. Whether you choose to tap into the grid or build a solar system to go entirely energy independent, we’re here to help you get exactly what you need.
Shop Home EV Charging Solutions at NAZ Solar Electric
There’s a lot to think about when deciding how to gain energy independence and reduce your reliance on fuel, and our team is happy to walk through any questions you have. You can shop our EV chargers or EV solar charging kits online, or reach out to us with any questions.
Get Started Designing Your Solar Setup
Our application engineers are always on hand, ready to help you design a system that meets your needs today and is scalable for the future. To get started, make an appointment today!
Share:
