Lithium Battery Theory | Fundamentals of The Main Components
Date Published:
Energy storage systems (ESS) are critical for meeting the growing demand for clean, reliable, and affordable energy.
Lithium batteries have emerged as a leading technology for ESS due to their high energy density, long cycle life, and safety.
The construction of residential and commercial lithium batteries, integral to Energy Storage Systems (ESS), is fundamentally based on two core components: the cells and the Battery Management System (BMS). A technical overview of how these components are assembled and function within an ESS battery provides insight into the sophisticated yet elegant design of modern energy storage solutions.
Lithium Battery Cells
Lithium battery cells, are the basic building blocks of an ESS, the cells are where energy is stored, and power is delivered. These cells can be of various chemistries, the most common Lithium-Ion chemistry for residential and commercial energy storage systems is, Lithium Iron Phosphate (LiFePO4). The cells are typically cylindrical or prismatic in shape. In constructing an lithium battery, multiple cells are connected in series and/or parallel configurations to achieve the desired voltage and storage capacity. Series connections increase the voltage level, while parallel connections increase the storage, ampere-hour (Ah) capacity. This arrangement is encased in a protective housing that shields the cells from physical damage and environmental factors.
The BMS is the intelligence hub of the battery, ensuring optimal performance, safety, and longevity. It continuously monitors various parameters such as voltage, current, and temperature of the battery and cells. Based on this data, the BMS can make real-time decisions to regulate the charging and discharging processes. It also serves to balance the cell voltages to ensure uniformity, preventing overcharging or deep discharging of individual cells, which can permanently harm the cells. The BMS also plays a critical role in thermal management, maintaining the battery within a safe temperature range. It can initiate thermal management systems or even disconnect the battery in case of extreme temperature conditions. Additionally, the BMS monitors the state of charge (SoC) and in some cases state of health (SoH) of the battery, providing vital information about available energy and overall battery health. This data is crucial for effective energy management in applications like solar energy storage, backup power systems, and grid support systems.
Lithium Battery Cell and BMS | Teamwork
The cells and BMS in an lithium battery work in tandem to provide a reliable and efficient energy storage solution. The cells store and provide the energy, while the BMS ensures this process is done safely and effectively within the limits of the battery and BMS. Understanding these components is key to grasping the overall functionality and value of modern ESS batteries, forming a foundation for deeper exploration into battery theory and technology.
To learn more about Lithium Batteries: LEAD IS DEAD, Batteries for Solar Applications – Chemistry, Care, and Terminology, Batteries and Battery storage, Introducing: The Pytes – V5°, Top 10 Signs of Battery Degradation
To shop Lithium Batteries:Pytes-V5, Discover AES 48-48-5120, Fortress Power eVault Max 18.5, Discover AES 42-48-6650, Fortress Power eFLEX 5.4
To talk with an application engineer:
Emails: sales@solar-electric.com
Call: 1.800.383.0195
Or chat live on our website during business hours.
Need Help with Your Solar Project? Request a quote Ask a question
