Magnum Inverters and Accessories
Magnum Energy inverters are our most popular inverter/chargers for RV's. We carry all Magnum inverter products. Export versions are not listed but we can special order them, usually 2-4 days.
Magnum Energy is a leading manufacturer of premium inverter/chargers for Mobile, RV, Marine, Off-grid and Solar applications. New technology battery charger design using power factor correction techniques, innovative first in modified sine wave platforms. Magnum's unique die-cast aluminum base allows full ratings up to 45C for superior high-temperature operation.
Power Factor Corrected (PFC)Charger: The PFC charger is built into all Magnum inverters/chargers. It uses less energy from a generator than a standard charger, using only 15 amps AC per 100 amps versus 23 amps used by standard chargers.
Made in the USA - all Magnum inverter products are manufactured at their facility in Everett, WA.
Please call us for information about our latest deals and specials on Magnum brand inverters and equipment. If you find a lower advertised price on the Internet, we can probably beat it.
NOTE: We are an authorized Magnum Energy dealer. Be careful when browsing the internet for deals on Magnum equipment. According to Magnum's policy, the warranty on equipment purchased from unauthorized dealers is null and void. If you see a price that looks too good to be true, it probably is.
Magnum Energy Modified Sine Wave Inverters & Accessories
ME Series Inverter/Charger. Designed for mobile applications in RV, marine and truck markets where 12-volt input is common. The ME Series is the easiest inverter/charger to install and operate on the market. Competitively priced, the ME Series is available in 2000, 2500, and 3100-watt models.
MM Series Inverter/Charger. The MM Series Inverter is designed to accommodate entertainment systems and small appliances in smaller RVs and boats. Available in 600 and 1200 watt models - the MM series in an all-new design - is the most cost-effective inverter available from Magnum Energy.
MM-E Series Inverter/Charger (export). The MM-E Series Inverter/Chargers are designed for countries that use 230VAC/50Hz power. The MM-E Series Inverter is smaller, lighter and less expensive while retaining all the built-in protection and reliability of ME and MS models.
MM-AE Series Inverters. The MM-AE Series inverter is smaller, lighter and less expensive while retaining all the built-in protection and reliability of ME and MS models. The built-in chargers for the MM-AE Series use a PFC (Power Factor Corrected) charger, which is 85% efficient and the same charger topology used in all Magnum charger models. The MM-AE Series is designed to accommodate smaller loads and appliances in cabins and off-grid homes.
RD Series Inverter/ChargersDesigned for Renewable Energy applications. The RD Series uses the same construction as the ME Series without a neutral bonding relay. Available in 1800, 2200, 2800, and 3900-watt models.
Magnum Sine Wave Inverters with Charger & Accessories
Magnum Energy 12, 24 & 48 Volt Sine Wave Inverter/Chargers & Accessories.
Includes remote controls, generator start modules, etc.
The MS Series Inverter/Charger is a pure sine wave inverter designed specifically for the most demanding mobile and off-grid applications. The MS Series is powerful, easy-to-use, and best of all, cost-effective. Install the MS Series in four easy steps: simply connect the inverter's output to your distribution circuits or electrical panel, connect your shore power cable (AC) to the inverter's easy-to-reach terminal block, connect the batteries, and switch on the power.
The MS-PAE SeriesInverter/Charger from Magnum Energy is a pure sine wave inverter designed specifically for the most demanding renewable energy applications. The unique design of the MS-AE Series can provide 120 and 240 volts AC output in one unit, eliminating the need to stack two units together to get 240 volts. Available in 4000 (24 volts) and 4400 (48 volts) watt models, the MS-AE Series inverters are powerful, easy-to-use and ETL listed to the stringent requirements of UL 1741 and CSA C22.2 No. 107.1-01 for Renewable Energy installations.
What are the benefits of the Prewired Magnum Energy System?
1. It includes the Magnum Mini Panel (MMP).
- The inverter comes standard with a 3-year warranty without the MMP and a 5-year warranty with the MMP.
2. It includes the Advanced Remote (ME-ARC50) and the Automatic Generator Start (AGS).
- With the ME-RC50 standard remote, the AGS is only capable of basic adjustments based on battery voltage or temperature. When using the ME-ARC remote, the ME-AGS-N has advanced start and stop settings based on time of day, battery State of Charge, battery voltage, high temperature, or inverter load amps. It also includes the ability to manually turn the generator on and off, generator exercise, warm up and cool down.
3. It is customizable.
- If you do not want the AGS, or want to use the standard RC50 remote instead of the ARC50, then just let us know. The price of the kit is simply the sum of the prices of the individual components. For example, if you take out the AGS, the total price is reduced by the price of the AGS.
There is a similar prewired system offered by Midnite Solar that uses the MidNite E-Panel. This means the inverter would have a 3-year warranty. It comes with the basic RC50 remote and AGS. NAZ Solar Electric includes both the ARC50 and the AGS.
