Manufacturers & Brands
LG’s NeON™2 solar panel is one of the most efficient commonly available 60-cell modules on the market. LG considers the fact that the amount of energy generated by solar panels differs from day to day due to factors such as weather, temperature, and shading. This is why they create their solar panels with quality and efficiency in mind.
Solartech Power Products
Solartech modules employ the best quality cells from Solartech's own cell lineup. Combined with superior material and Taiwanese workmanship, Solartech modules will meet and exceed the durability and performance requirement whether they are for residential, commercial or utility projects. Solartech modules are TUV, ETL, and UL certified.
E Panels
The Magnum E-Panels made by Midnite Solar come with an inverter breaker, 2/0 inverter cables, pre-wired AC input and bypass, 500amp 50mV shunt, AC terminal blocks, 100 amp DC positive and DC negative bus bars, PV input bus bar, din rails, 3 panel mount breaker knockouts, Ground bus bar, DC wiring cover, top shield, remote display mounting bracket, wall mounting brackets, charge controller bracket and lots of hardware and grommets.
Magnum Energy Inverters & Accessories
Magnum Energy is a leading manufacturer of premium inverter/chargers for Mobile, RV, Marine, Off-grid and Solar applications. New technology battery charger design using power factor correction techniques, innovative first in modified sine wave platforms.
Schneider Electric Inverters & Accessories
As the global specialist in energy management, Schneider Electric provides complete photovoltaic solutions for any size installation, from grid‐tie residential rooftops and utility‐scale farms to off‐grid solar and battery backup application.
Exeltech Sine Wave Inverters
Exeltech inverters have an MTBF (mean time between failure) in excess of 20 years and offer the most competitively priced ultra-reliable true sine inverters available anywhere. Exeltech provides back up power for the communications room in every U.S. Embassy, worldwide.
Samlex Sine Wave Inverters
The Samlex America name is synonymous with power supply value. Since 1991, Samlex has manufactured and distributed power supply products to more than 90 countries worldwide. Innovative product designs, strict quality control, and responsible after-sales service provide customers with high-quality power conversion products at extremely competitive prices.
Fronius Grid-Tie Inverters
The latest and greatest Fronius grid-tie inverters are the IG Galvo and Primo lines, which are fully NEC 2014 and UL compliant. They come with built-in ground fault protection, DC reverse polarity protection, islanding protection, over temperature protection, and arc-fault circuit protection.
SMA Sunny Boy Grid-Tie Inverters and Accessories
The Sunny Boy solar inverters characterize the technology and quality-leadership of the company. They are optimally suitable for use in small and mid-range systems. They impress with first class efficiency, user-friendliness, and reliability.
Enphase Microinverters
The Enphase Energy Solar Micro-inverter system is a set of small units that connect directly to each solar module to convert DC power into grid-compliant AC power and transmits valuable performance data on each module to the system owner.
Conext XW+ Sine Wave Inverters and Accessories
A Conext XW solar system provides up to 36 kW by using modular components. All components communicate with each other with out‐of‐the‐box network capability. They include the Conext XW Inverter/Chargers, the Solar Charge Controllers, the Conext XW Automatic Generator Start (AGS), and the Conext XW System Control Panel (SCP).
Midnite Solar Products
Whether you lack the experience or knowledge to build your own system or if you simply want to save time on installation, the MidNite Solar Prewired E-panels are an excellent option.
Outback Power Products and Accessories
Grid-Interactive? What does THAT mean?? Grid-interactive is kind of a hybrid system, battery-based but they also feed any excess power back to the grid and draw from the power grid when the solar panels are not producing enough.
