New MidNite Solar Batteries: MNPowerflo5 and MNPowerflo16
Date Published:
MidNite Solar has introduced two new advanced lithium iron phosphate (LFP) batteries, the MNPowerflo5 and MNPowerflo16, designed to cater to the diverse energy storage needs of residential, commercial, and industrial applications. These batteries stand out due to their remarkable capabilities, safety features, and competitive edge in the market, priced to allow you to build or expand your system today! Both batteries pair seamlessly with the MidNite Solar All-In-One Inverter!
Contact NAZ Solar Electric to pre-order your MidNite Solar Batteries or to request more information at 1.800.383.0195
MNPowerflo5 Overview
The MNPowerflo5 is a rack-mounted battery with the following key specifications:
  • Energy Capacity: 5.12 kWh
  • Nominal Voltage: 51.2V
  • Cycle Life: 6,000 cycles at 77°F (25°C), 0.5C/0.5C
  • Battery Chemistry: Lithium Iron Phosphate (LFP)
  • Dimensions: 17.7 x 17.4 x 5.2 inches
  • Weight: 96.5 lbs
  • Scalability: Up to 16 units in parallel, allowing for an energy capacity of up to 81 kWh
  • Compliance: UL 1973, UL 9540A, UL9540
  • Applications: Suitable for residential, commercial, industrial, off-grid, grid-tie, and self-consumption applications
Competitive Edge and Capabilities
  1. Safety and Longevity: The MNPowerflo5 uses EVE A+ grade lithium iron phosphate cells, recognized for their safety and long life, making them ideal for energy storage. The 15-year design life is among the longest in the industry.
  2. Advanced Battery Management System (BMS): The integrated BMS offers multi-level protection, automatic address assignment, and remote firmware upgrades, enhancing user convenience and battery performance.
  3. Ease of Installation: The battery is compatible with all 48V inverters that support LFP and can be easily installed in a standard 19-inch server rack, making it a flexible solution for various installations.
  4. Smart Communication: The battery can automatically identify inverter protocols and communicate with the MidNite AIO inverter in a closed loop, ensuring seamless integration and efficient operation.
  5. Scalability: With the ability to connect up to 16 units in parallel, users can easily expand their energy storage system as needed.
Shop MNPowerflow5 | Shop MNPowerflow16 | Request more info
MNPowerflo16 Overview
The MNPowerflo16 offers higher energy capacity and is designed for larger applications:
  • Energy Capacity: 16 kWh
  • Cycle Life: 8,000 cycles at 77°F (25°C), 0.5C/0.5C
  • Dimensions: 31.50 x 19.69 x 19.69 inches
  • Weight: 284 lbs
  • Scalability: Up to 16 units in parallel, allowing for an energy capacity of up to 257 kWh
  1. Enhanced Energy Density: The MNPowerflo16 boasts a high energy density of up to 178Wh per kilogram, allowing for a more compact installation without sacrificing storage capacity.
  2. Longer Design Life: With a 20-year design life, this battery ensures long-term reliability and lower replacement costs.
  3. Active Balancing: The battery actively balances at 2 amps, improving efficiency and state-of-charge (SOC) reporting, which helps maintain optimal performance.
  4. Robust BMS: Similar to the MNPowerflo5, it features a multi-level protection BMS, remote firmware upgrades, and smart communication capabilities.
  5. Versatile Installation: It can be wall-mounted or floor-mounted, offering flexibility in installation options depending on space availability and requirements.
Conclusion
The MNPowerflo5 and MNPowerflo16 from MidNite Solar are competitive additions to the energy storage market, offering robust safety features, long cycle life, and scalability. These batteries are designed to meet a wide range of energy storage needs, making them an excellent choice for anyone looking to invest in reliable and efficient energy storage solutions. Whether for residential, commercial, or industrial applications, the MNPowerflo series delivers performance and reliability that can be counted on for years to come.
You can download the PowerPoint slides here.
Need help? Contact our Sales Engineers.
sales@solar-electric.com
1.800.383.0195
Request Information
Need Help with Your Solar Project? Request a quote Ask a question
