Midnite Solar Products
MidNite Solar Factory Built and Prewired Battery-Based Systems
Whether you lack the experience or knowledge to build your own system or if you simply want to save time on installation, the MidNite Solar Prewired E-panels are an excellent option. The systems come with the inverter, main DC inverter disconnect, charge controller, surge protectors, ground fault protector, and a system display panel. Please see the item descriptions for a detailed list of components. MidNite Solar currently offers prebuilt systems for Magnum and Outback inverters.
The AC coupled systems also require a grid-tie solar system. Basically, the AC coupled system uses the power from a grid-tie system to keep batteries charged and will provide backup power when utility power is unavailable.
Need Help with Your Solar Project? Request a quote Ask a question
