Solartech Power Products
Solartech modules employ the best quality cells from Solartech's own cell lineup. Combined with superior material and Taiwanese workmanship, Solartech modules will meet and exceed the durability and performance requirement whether they are for residential, commercial or utility projects. Solartech modules are TUV, ETL, and UL certified.
What Can I Charge?
Solartech has the perfect modules for charging small to large size batteries. With solar modules between 5-140 watts and 12 and 24 volts, there is a module for every application. An array of certain modules can also be configured for charging 12, 24 or 48-volt battery banks. Solartech solar modules are ideal for RV's, off-grid battery charging, powering remote communications equipment, small water pumping systems, and residential or commercial grid-tie systems.
Solartech’s Easy Install
Solartech solar modules either have a sealed weatherproof junction box and electrical leads with ring terminals for easy connection to most batteries with screw or bolt terminals, or come with MC4 connectors for a quick and easy installation. If you are unsure about your setup and need some advice, please contact us to speak to one of our experienced sales staff. We will be more than happy to help you design your system.
