Solar Panels
At NAZ Solar Electric we proudly provide an extensive selection of premium photovoltaic (PV) solar panels modules and related equipment. Our product range features the leading brands in the photovoltaic industry encompassing all major solar panel types to ensure an ideal match for your energy system. Our panels are designed to fulfill your energy needs whether you're looking to enhance your home's efficiency lower your utility bill or take your energy system completely off-grid.
Why Choose NAZ for Photovoltaic Solar Panels
  • Versatile Selection: Choose from our extensive range of professional-quality solar panels including high-efficiency monocrystalline cost-effective polycrystalline and flexible options for voltage and power. Each brand in our portfolio has been chosen for its proven track record of commercial-grade durability and outstanding performance. If we don’t believe in it we don’t sell it.
  • Energy Savings: Our photovoltaic panels efficiently convert sunlight into electricity significantly reducing your energy expenses when connected to the utility grid.
  • Increased Property Value: Installing PV panels is not only a green energy choice but can also enhance your property's value.
  • Eco-Friendly Choice: Make a positive impact on the environment by reducing your carbon footprint with our sustainable solar solutions.
  • Long-Term Investment: With durable and efficient photovoltaic panels available you're investing in a future of energy independence backed by comprehensive warranties.
DIY or Professional PV Panel Installation?
At NAZ Solar Electric we cater to both wholesale and retail customers. Whether you're a hands-on DIY enthusiast (check here for helpful DIY information) or prefer a professional installation our selection of solar panels includes industry-standard components such as junction boxes and MC4 connectors making installation easy. This ensures that no matter your approach your equipment meets rigorous quality standards. Our range of photovoltaic panels is chosen with versatility in mind perfect for the customizable needs of residential and commercial projects. We can even help you find a professional installer in your area.
Shop Our Range of Photovoltaic Solar Modules
NAZ Solar Electric distinguished by its industry-recognized expertise sets the standard in PV design and innovation. The solar modules we offer are selected for their high efficiency and cost-effectiveness meeting a broad spectrum of energy needs. Our expert customer support team is committed to guiding you through our options to find the perfect solar PV kit or design for your residence or application. Step into the future of renewable energy with NAZ Solar Electric's wide selection of photovoltaic solar panels.
Powering Your Solar Journey: The NAZ Approach
Embark on your solar journey with confidence through The NAZ Approach, our comprehensive process that guides you from initial consideration to installation and beyond. We stand by you at every step ensuring personalized solutions and technical support throughout the lifespan of your solar system. With The NAZ Approach we transform the complexity of adopting solar energy into a seamless and supported experience tailored to your unique needs.
Connect with NAZ Solar Experts Today
Have questions about our solar panels or services? Reach out to us! Our team at NAZ Solar Electric is ready to guide you on the path to your solar solution.
Have additional questions about solar panels? Our Learning Center’s article on Solar Panels and Mounts is a great place to start. Discover a wealth of information on solar power and its uses in our Learning Center.
Toll free: (800) 383-0195
Email us at: sales@solar-electric.com
Need Assistance?
Do you have questions about our solar panels? Need a solar system customized to your needs? Our solar application engineers are on standby to provide you with the answers and solutions you need. Would you like to be contacted by one of our solar engineers?
EmailCall
Items 1-20 of 52
SLD Tech ST-5P-12 5 Watt, 12 Volts Monocrystalline solar module
$22.84
SLD Tech ST-5P-06 5 Watt, 6 Volts Monocrystalline solar module
$22.84
SLD Tech ST-5Q-06 solar panel, 5W 6V monocrystalline module with aluminum frame and six mounting holes
$18.85
Solarland SLP005-12U 5 Watt 12 Volt Polycrystalline Solar Module
$22.84
($4.57/W)
Ameresco BSP2-7 2 Watt 7 Volt Solar Panel
$23.96
($11.98/W)
Ameresco BSP2-12 2 Watt 12 Volt Solar Panel
$23.96
($11.98/W)
Ameresco BSP1-12 1 Watt 12 Volt Solar Panel
$25.89
($25.89/W)
SLD Tech ST-10R-12 10 Watt, 12 Volts Monocrystalline Solar Module
$35.53
Ameresco BSP5-12 5 Watt 12 Volt Solar Panel
$33.66
($6.73/W)
$35.53
SLD Tech ST-20R-12 20 Watt, 12 Volts Monocrystalline Solar Module
$52.20
Out of stock
Ameresco BSP10-12 10 Watt 12 Volt Solar Panel
$54.20
($5.42/W)
SLD Tech ST-30P-12 30 Watt, 12 Volts Monocrystalline solar module
$87.00
SLD Tech ST-30P-24 30 Watt 24 Volt Monocrystalline Solar Module
$87.00
SLD Tech ST-030R-12CID2-QC solar panel, 30W 12V monocrystalline module with anodized frame, Class I Division 2 hazardous-location rated
$80.56
Ameresco BSP10-12LSS 10 Watt 12 Volt Solar Panel
$86.96
($8.70/W)
Ameresco BSP20-12 20 Watt 12 Volt Solar Panel
$96.50
($4.82/W)
Ameresco BSP30-12 30 Watt 12 Volt Solar Panel
$111.85
($3.73/W)
SLD Tech ST-65P-12 65 Watt, 12 Volts Monocrystalline solar module
$141.65
